2009: No IPTC plugin???
mhulse's avatar
mhulse
16 years ago
mhulse's avatar mhulse
Just wanted to confirm…
TRUE/FALSE: There is no IPTC image plugin for EE?
For example, I would like to do this (pseudo code):
{blah:iptc image="{my_custom_image_field}" param="foo" param="foo"}
{blah_caption}
{blah_other}
{/blah:iptc}
If FALSE, do ya’ll think there would be a need for such a plugin?
Thanks, Micky
Adrienne L. Travis's avatar
Adrienne L. Travis
16 years ago
Adrienne L. Travis's avatar Adrienne L. Travis
There is not one. I would LOVE one. IPTC+EXIF would really be even better for me, but i’d settle for what i could get!
(There was, a while back, a partial EXIF plugin someone wrote for EE, but it never worked all that well and i’m pretty sure it’s no longer supported.)
mhulse's avatar
mhulse
16 years ago
Hi Adrienne!
Thanks for the reply.
I think it is about time someone wrote one… If I have some spare time, I will dig into this.
I think the exif plug you mention can be found here:
http://expressionengine.com/downloads/details/exif/
I just tried to get that working, but the server I am on does not support php exif functions. :(
IPTC, on the other hand, (FWIK) is supported on my server… I think IPTC reading method(s) is/are standard with PHP4/5+:
http://us2.php.net/iptcparse
Anyway, looks like there is a need for this… I know that my bloggers would probably prefer to not have to extract the caption info manually for every photo. 😊
If I make any progress I will post back here! Thanks for you reply, I really appreciate it!!!
Cheers, Micky
Adrienne L. Travis
16 years ago
From your link, they’re no more standard with PHP than EXIF is, because iptcparse / iptcembed are part of the GD library. But it is true that most hosts compile in support for GD. 😊
mhulse's avatar
mhulse
16 years ago
Ah, I did not realize that! 😊
Thanks for the clarification.
I am not the best coder in the world, but I love a good challenge… Seems like the EXIF plugin woult be a good starting point for an IPTC/EXIF plugin.
Thanks Adrienne!
Have a great day, Cheers, Micky
Adrienne L. Travis
16 years ago
Sounds like it to me too – perhaps check with Lodewijk to see if he minds you taking it over. He probably wouldn’t.
And one of the local development servers – XAMPP (for PC) or MAMP (for Mac) or whatever – would be able to get the EXIF additions compiled in easily if it didn’t already have them. So that might be how you wanted to handle development!
mhulse's avatar
mhulse
16 years ago
Good idea! I will do that. 😊
Another excellent idea! Thanks a billion Adrienne!!! 😊
I will post back here when I make some progress on this venture. :D
Have a wonderful day.
Cheers, Micky
