I am using FF FieldFrame Matrix. Although I have no problems saving entries using this (except for multibyte characters), if the LG Better Meta extension is enabled I get the following when clicking “Update” (or “Submit”):
Notice: unserialize() [function.unserialize]: Error at offset 209 of 2600 bytes in /Applications/XAMPP/website/system/extensions/ext.lg_better_meta.php on line 811 Warning: Cannot modify header information - headers already sent by (output started at /Applications/XAMPP/website/system/extensions/ext.lg_better_meta.php:811) in /Applications/XAMPP/website/system/core/core.functions.php on line 296
Anything I can do? Should I not use FF FieldFrame?
I am using FF FieldFrame Matrix. Although I have no problems saving entries using this (except for multibyte characters), if the LG Better Meta extension is enabled I get the following when clicking “Update” (or “Submit”):Notice: unserialize() [function.unserialize]: Error at offset 209 of 2600 bytes in /Applications/XAMPP/website/system/extensions/ext.lg_better_meta.php on line 811 Warning: Cannot modify header information - headers already sent by (output started at /Applications/XAMPP/website/system/extensions/ext.lg_better_meta.php:811) in /Applications/XAMPP/website/system/core/core.functions.php on line 296Anything I can do? Should I not use FF FieldFrame?
How many weblogs do you have in your site?
