I am trying to encrypt a paypal button that I am generating with Mark Bowens Shopping Cart plugin. In an old thread I read that this may be possible with the built-in encryption of the SCM, but the example given does not really help, because I do not know how to implement it.
In a newer thread I found a php solution that seems to be able to do what I want.
I tried to get it working, but I must be doing something wrong because my EE tags either don’t get parsed and cause a php error or the tags are parsed but the php is inserted into the site as text…
I tried different combinations of embeds, nothing worked, and now I am confused and do not know how to tackle this.
Moved to Plugins by Moderator
Just updated the thread that I created some time back. Unfortunately no good news except that I did get it to work with hard-coded values but I haven’t tested with ExpressionEngine values as of yet.
You definitely have PHP parsing turned on for the templates where you are using PHP don’t you?
Best wishes,
Mark
I think it’s a technical issue because I am having problems with template parsing order and I need someone to help me with that!
Sorry point taken. Just wanted to say that it’s not so much a problem with the plugin as you don’t have to use the plugin to create the links that you currently have.
