PHP Errors, Notices, and Warnings in MAMP Pro
Ian Young's avatar
Ian Young
16 years ago
Ian Young's avatar Ian Young
I’ve just installed the FieldFrame extension but when I go to create a new field under Admin > Weblog Administration > Field Groups > Custom Fields, the following errors are displayed at the top of the page:
Notice: Use of undefined constant FT_URL - assumed ‘FT_URL’ in /Users/name/Sites/site.com/system/extensions/ext.fieldframe.php on line 2573 Notice: Use of undefined constant FT_URL - assumed ‘FT_URL’ in /Users/name/Sites/site.com/system/extensions/ext.fieldframe.php on line 2578 Notice: Use of undefined constant FT_URL - assumed ‘FT_URL’ in /Users/name/Sites/site.com/system/extensions/ext.fieldframe.php on line 2578 Warning: Invalid argument supplied for foreach() in /Users/name/Sites/site.com/system/extensions/fieldtypes/ff_matrix/ft.ff_matrix.php on line 305
I presume this is probably more of a PHP error display setting in the php.ini file but I’m not sure which setting is best to change to prevent these errors without turning off important errors I need to see.
I’m using MAMP Pro on the Mac. Can someone recommend the settings to change to prevent these notices/warnings?
Lisa Wess's avatar
16 years ago
Lisa Wess's avatar Lisa Wess
Hi, Ian,
You should never suppress errors; they are a sign that something is wrong, hiding this is not the correct way to “fix” them.
I am going to move this down to the extensions forum, and I’d recommend contacting FieldFrame’s author for assistance troubleshooting.
Ian Young's avatar
Ian Young
16 years ago
Hi Lisa,
Thanks for the info. I just presumed it was something that I needed to tweak on the server than a problem with the FieldFrame extension.
In that case, has anyone had similar notices/warnings using this extension?
