LG TinyMCE plugin troubles
shannondesigner's avatar
shannondesigner
16 years ago
shannondesigner's avatar shannondesigner
I’ve read many posts on this plugin and how people can’t get it to work at all on the edit screen. I have EE 1.6.7 and LG TinyMCE 1.3.3. The WYSIWYG fields work great when you go to publish in a weblog the first time. If you return and try to edit the post, the wysiwyg fields are gone. Then, if you go to publish a new post, the fields are gone until you clear the site cache and it works again for new posts only. I really need to get this working so I can hand this over to clients and allow them to publish content on their site. Let me know if anyone has any ideas for me, thanks!
shannondesigner
16 years ago
I fixed the problem! I am using TinyBrowser with TinyMCE and the code that I added to the file ext.lg_tinymce.php was incorrect. In order to get TinyBrowser to work, you need to add this line to that file:
$r .= "n" . '[removed]settings['script_path'])) .'">[removed]';
It goes right after this line:
$r .= "\n" . '[removed]settings['script_path']) . '">[removed]';
shannondesigner
16 years ago
Hmm it appears my code didn’t work. The original code can be found here but he has an extra space in there.
Envoc Creative's avatar
Envoc Creative
16 years ago
Envoc Creative's avatar Envoc Creative
I don’t have a solution but can add that I noticed I have the same problem, but only in Safari 4 on mac. In firefox and IE on both mac and PC, i don’t have any problem with it. If I disable caches in safari, it works without a hitch.
