Freeform vs SAEF?
Jim Wyse's avatar
Jim Wyse
16 years ago
Jim Wyse's avatar Jim Wyse
I’m working on a site that will have many forms for people to request a multitude of things. My question is about using Freeform, with all the fields for all the forms, or use the saef with a weblog for each. Doesn’t saef require the user to be logged in. I remember seeing somewhere a thread with an autologin script.
Thoughts? Each seems to present it’s own pros and cons.
Jim
eyevariety's avatar
eyevariety
16 years ago
eyevariety's avatar eyevariety
Unless you need to use the data that they enter as entries then you probably just want to use freeform.
SAEF is used as an interface for outside users to get content into your system- not really as a contact/request form.
