What does $DB->insert_id return if there is no primary key defined?
Eric Snyder's avatar
Eric Snyder
16 years ago
Eric Snyder's avatar Eric Snyder
Title says it all…does anybody know off hand?
Eric Snyder
16 years ago
It returns a zero. I want to be able to go back and delete the row I just inserted at a later time. For the tables that have and autoincrimenting primary index it would work fine to use the result of $DB->insert_id but want about those tables that do not?
