TinyMCE Templates within EE, using LC TinyMCE Extention
atrowbri's avatar
atrowbri
16 years ago
atrowbri's avatar atrowbri
For those unaware, you can build templates in TinyMCE that offer structured HTML that a client can drop into a TinyMCE WYSIWYG window and then edit.
http://wiki.moxiecode.com/index.php/TinyMCE:Plugins/template
I cannot get it to work if I put the template into the [ ] (see “Templates example” in the link above. However, I can get it to work if I do the following:
  1. TinyMCE must be installed and working in your Expressionengine install.
  2. In the Expressionengine backend, go to: Admin > Utilities > Extensions Manager
  3. Next to “LG TinyMCE” click “Settings” to edit the settings.
  4. In the “plugins :” paramater, add “template” to the list
  5. In the “theme_advanced_buttons1 :” parameter, add “template” to the list
  6. Somewhere in the settings, add the line: template_external_list_url : “tinymce_templates/templates.js”,
  7. Save the settings.
  8. In the “System” directory, create a directory named “tinymce_templates”
  9. You are now ready to build your TinyMCE templates.
I have this working with: LG TinyMCE (v.1.3.2) TinyMCE Version 2.1.2
This was a fantastic victory until I tried it with TinyMCE Version Version 3.0rc2 and Version 3.2.5
In these versions the Template icon shows up and opens a window but no templates are listed. The only difference I can see between 2.1.2 and the more recent versions is that 2.1.2 opens an actual browser window for template selection and the more recent versions open a javascript window for template selections.
Does anyone else use TinyMCE templates with EE? Does anyone have them working with up-to-date TinyMCE? Any help is greatly appreciated as it took a long time to get it working in the first place and now I’m back to the start.
