NSM Publish Plus & LG Live Look
osadmin's avatar
osadmin
16 years ago
osadmin's avatar osadmin
I purchased NSM Publish Plus and I am trying to get it to work with LG Live Look which are meant to be compatible. When I have both running I am having an issue when trying to publish new or edit existing articles as I am just getting a blank white screen. Checking the source also does not show any code. If I disable one of the extensions then the other works.
I have followed instructions several times and the only time this is an issue is when both the extensions are running together.
Hope someone can assist!
osadmin's avatar
osadmin
16 years ago
Worked this one out with the aid of another developer. The memory was set to 8M and needed increasing so that the extensions could both run.
