MX *Title Control (EE1 / EE2) - take control of your *Title & URL title field label
Max Lazar's avatar
Max Lazar
16 years ago
Max Lazar's avatar Max Lazar
MX *Title Control is an ExpressionEngine (1.6.x/2.x) extension that allows you to change the *Title & URL title field label for each of weblog and (optional) for each of languages. + MSM compatible + MultiLanguages support *Multilanguage blocks created based on your EE language folders
EE1 extension page
EE2 version in attachment
And remember – if you have any issue or bugs, feel free to send me a note and I will help you ASAP.
Versa Studio's avatar
Versa Studio
about 16 years ago
Versa Studio's avatar Versa Studio
Awesome, I’ve always wanted this option.
Adrienne L. Travis's avatar
Adrienne L. Travis
about 16 years ago
Adrienne L. Travis's avatar Adrienne L. Travis
There’s another extension called ‘BN Title Changer’ that does the same thing, but it hasn’t been updated in awhile. And your UI looks better!
http://ellislab.com/forums/viewthread/110860/
Chris Newton's avatar
Chris Newton
about 16 years ago
Chris Newton's avatar Chris Newton
What’s there to update?
But anyway, glad to see there’s one that’s multi-language capable. I’ve never even had a request to build a multi-language site, so there’s never been a personal need for that in my plugin.
Max Lazar's avatar
Max Lazar
about 16 years ago
Yes, I was used this ext. before, but unfortunately the BN Title Changer don’t really want work with MSM + this ext’s have a different working methods - BN works by JS, MX makes changes on page in the moment of creating in the system.
p.s. by the way - for Multilanguage I used Mx title with another ext which helps to create Multilanguage label for customs fields. I will publish it later.
Adrienne L. Travis
about 16 years ago
Fair enough, Chris. 😊 BN Title Changer is pretty simple. I’ve been using it for months now, it’s saved me a lot of documentation headaches! Just wanted to put the link here in case anyone came along wanting to compare/contrast.
It also looks like this one requires PHP 5+, and i think that yours is PHP 4 safe, isn’t it? So that’s an important difference.
Max Lazar's avatar
Max Lazar
about 16 years ago
Actually I just don’t have PHP 4 for testing, but I don’t think that used something really unsupportable by PHP4.
Chris Newton
about 16 years ago
Hm, that’s interesting. I’d considered doing that myself. I think it’s a great approach. I think I used the JS method just to make sure it’d be easy to update in the future if anything changed under the hood in EE, which is probably not really an important concern anyway. To be fair to Adrienne L. Travis above… I never wanted to bulid something that needed any maintenance or updating 😊
I haven’t yet even tried my extension with MSM (though my own site is MSM, so I guess I’ll have to get around to updating it) Anyway, I don’t mean thread hijack, I just wanna say it’s great that there’s one out there that does the job for msm & multi-language. Good add.
Kristof Rutten's avatar
Kristof Rutten
15 years ago
Kristof Rutten's avatar Kristof Rutten
Great job! Works like a charm and very intuitive!
sm9's avatar
sm9
15 years ago
sm9's avatar sm9
Hi Max.
Are there any plans to port this over to EE2? I thought that you might be able to edit the Title field natively in EE2 as there’s a little pencil icon next to the fields when you show the Toolbar, but clicking in doesn’t do anything for me (unless I’m hitting a browser issue!) so I guess not.
Thanks.
Max Lazar's avatar
Max Lazar
15 years ago
yeah, I have the plans(actual – I really need it too), but it’s still not possible to do it right way because most part of hooks is still out of EE2. Waiting for next EE2 build
sm9's avatar
sm9
15 years ago
sm9's avatar sm9
Thanks for letting me know - good to see it’s in your plans when the right hooks are available.
Max Lazar's avatar
Max Lazar
15 years ago
EE2 version is ready. Enjoy!
Brent Cartier's avatar
Brent Cartier
15 years ago
Brent Cartier's avatar Brent Cartier
This is fantastic Max! Something I’ve wanted in EE from day 1.
Thanks for sharing!
-Brent
Cem Meric's avatar
Cem Meric
15 years ago
Cem Meric's avatar Cem Meric
Thanks Max, you’re the man!
Now just waiting for MX UniEditor to become EE2 ready so we can start using it 😊
