Using a custom field to define search results.
CADAUDIO's avatar
CADAUDIO
9 years ago
CADAUDIO's avatar CADAUDIO
I’m sure there is an easy solution to this, but I can’t seem to locate one.
I have a set of products in the products channel, I want to use search: in a side bar and a custom field to define what those search results return.
This works:
{exp:channel:entries channel="products" dynamic="off" orderby="date"  search:product_sub_title="GXL" sort="desc" limit="2"}
This doesn’t:
{exp:channel:entries channel="products" dynamic="off" orderby="date"  search:product_sub_title="{products_used}" sort="desc" limit="2"}
Is it possible to use a text input from a channel field from a specific entry to define what another channel tag displays?
Thanks Much!
James Mathias's avatar
James Mathias
9 years ago
James Mathias's avatar James Mathias
This might be what you are looking for Dynamic Parameters if I understand the problem correctly.
Ingmar Greil's avatar
Ingmar Greil
9 years ago
Ingmar Greil's avatar Ingmar Greil
Looks like you are running into parse order issues here. For this to work you’d have to nest exp:channel:entries tags, which is generally not recommended. Have you tried an embedded template?
{exp:channel:entries ... }
{embed=group/template my_product_sub_title="{product_sub_title}"}
And then, in group/template you’d use something like
{exp:channel:entries search:product_sub_title="{embed:my_product_subtitle}"}
Makes sense?
ETA: Or, what James says 😊
CADAUDIO's avatar
CADAUDIO
9 years ago
Basically it’s like this.
I have a page of artists pulling from the “artists” channel.
Each one of these artists use specific products from the “products” channel.
So, within the artist’s channel -> publish -> artists I want to use a custom field to define the search for the products used in the side bar.
I’ve been thinking about using a cookie as a var, then using the var in search:product_sub_title=”“
Set var inside channel and use var to create cookie:
$(document).ready(function (){
//define var from channel field products used
var products_used = "{products_used}";
$(document).ready(function () {
//set cookie for var set above
Cookies.set('exp_products', products_used  );
Then retrieve cookie and us the var inside search:product_sub_title=”products_used”
But no luck. I guess there’s no way to use a js var inside an EE tag?
Edit: and oh, I have this $conf[‘protect_javascript’] = ‘n’; defined in my config file.
Setting the cookie using the channel field is working. It’s using the var to change the search keyword that’s not.
I suppose there’s a better logic to make this happen…
CADAUDIO's avatar
CADAUDIO
9 years ago
Got it! I had to turn PHP Parsing Stage to input. duh…
So basically, to summarize in case anyone else needs to do the same.
I set a cooking using https://github.com/js-cookie/js-cookie
I created a var out of my Channel Field within my Channel tag:
script
//set var on channel field "products used"
/script
Set Cookie with var:
script
//set cookie using var set above
/script
Then just echoed the cookie into my sidebar channel:
search:product_sub_title="<?php echo " ".$_COOKIE['exp_products']; ?>"}
Works like a charm.
Except you have to use ajax to load the sidebar, otherwise the cookie doesn’t read on first load.
