Possible to get entry_date and edit_date not localized in template?
Developer Preview
TJ Draper's avatar
TJ Draper
8 years ago
TJ Draper's avatar TJ Draper
Is it possible to get entry_date and edit_date to always output un-localized in a template?
{entry_date format="%g:%i %A"} – {expiration_date format="%g:%i %A"}
I need for that output to always read as the date set in the timezone the system is set up to use.
Kevin Cupp's avatar
Kevin Cupp
8 years ago
It should always use the site timezone for logged-out users, but you can force a timezone if you want by adding the timezone= parameter.
TJ Draper's avatar
TJ Draper
8 years ago
Sweet. Timezone parameter confirmed working. Is that in the docs? I can’t seem to find it anywhere, hence why I didn’t know to use it.
Kevin Cupp's avatar
Kevin Cupp
8 years ago
Great! Yes it’s here: https://docs.expressionengine.com/latest/templates/date_variable_formatting.html#timezone
TJ Draper's avatar
TJ Draper
8 years ago
Ah hah!
What’s odd is I searched for timezone in the search input up on the left and that didn’t come up. And I was looking in the wrong place for it otherwise.
Derek Jones's avatar
Derek Jones
8 years ago
h4s were not being indexed; fixed, thanks!
