Allow renaming of custom fields in Edit Publish Layout
Feature Requests
Helmi_xisnet's avatar
Helmi_xisnet
Helmi_xisnet's avatar Helmi_xisnet
As per topic, it would be nice if EE allows renaming of custom fields in the Edit Publish Layout settings.
For example, I have an Event channel. Instead of Entry Date, it is easier to understand if I rename it to Event Date.
Apart from the above, this will allow more flexibility of custom fields; i.e. user can use the same textarea custom field for both Blog and FAQ channel but with different names (Blog -> Blog Body; FAQ -> Answer).
