Grid Field edit screen in Fluid Fields uses tables instead of divs
Piper LeMoine's avatar
Piper LeMoine
Piper LeMoine's avatar Piper LeMoine
Hi EE Community,
I make judicious use of fluid fields in our EE5 installation and those include grid fields that includes two WYGWAM fields along with a few other fields. Weirdly, I had developed something similar in EE2 using the Blocks add-on instead of fluid fields.
The issue I’m running into in EE5 is that, in the edit screen within the fluid field, the grid field renders as a table, which makes the rows either very wide or the WYGWAM fields very very narrow with all the other field columns within the fluid field.
So my question is, is there a similar type of field like a grid field that uses divs instead of a table so that the different fields within the grid field would be stackable?
