Setting HTTP status code from plugin
Ben Kimball (UT)'s avatar
Ben Kimball (UT)
18 years ago
Ben Kimball (UT)'s avatar Ben Kimball (UT)
I’d like to be able to set the HTTP status code from my plug-in. I’m invoking it from prototype’s Ajax.Updater method, which will behave differently depending on whether it gets a 200 OK or 4xx/5xx error code back from the server. When I tested my code outside of an ExpressionEngine context, the following worked fine:
if ($email->Send()) {
    $this->return_data = 'Email sent!';
} else {
    header('HTTP/1.0 400 Bad request');
    $this->return_data = 'There was a problem sending your message. Please try again.';
However, once I put that inside my plugin and invoked it from a template, it stopped working. It looks like EE is overriding my 400 status code with its own 200 OK status code. Can I get around that?
Thanks, Ben
Ben Kimball (UT)
18 years ago
To put it another way: can I somehow avoid including any output from EE? Maybe by doing something like:
header('HTTP/1.0 400 Bad Request');
die('There was a problem with your email address.');
Thoughts?
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
Hi, Ben – first a disclaimer: I’m not a programmer. But! This recently came up in regards to forcing a 404 header on a given template, and in the end Derek posted several code snippets. The last solution was this one but you may wish to review the entire thread.
I hope that is of some help to you, at least. =)
Ben Kimball (UT)
18 years ago
Ah! That global $OUT looks promising, I’ll give it a shot. Thanks Lisa!
Ben
Lisa Wess's avatar
18 years ago
Sure! It was just a guess but I was following the thread and it seemed so similar to what you wanted that I figured it couldn’t hurt to point it out =)
Ben Kimball (UT)
18 years ago
Well, using $OUT didn’t work. But this did:
header("HTTP/1.0 400 Bad Request");
  print "Sorry, we couldn't send email to that address.";
  exit;
Cheers! Ben
