Switch variable not working on Solspace Tag Module
dolmance's avatar
dolmance
18 years ago
dolmance's avatar dolmance
Hello, the switch single variable is not working on my Tag Module:
{exp:tag:cloud weblog="weblog1"}<a href="/tag/{websafe_tag}/" class="{switch=">{tag_name}</a> {/exp:tag:cloud}
Does anybody has the same problem? Thank you. Xavi.
Lisa Wess's avatar
18 years ago
Lisa Wess's avatar Lisa Wess
I don’t see a switch variable in the docs - where are you getting it from?
Anyhow, yes - as Victor said, switchplus should work, and you can always post an FR on solspace.com/forums. =)
dolmance's avatar
dolmance
18 years ago
Sorry, I thought I could use the same variables as the entries tag. I’ll try that plugin then. Thank you both.
