How will upgrading EE affect existing extensions?
django6's avatar
django6
18 years ago
django6's avatar django6
I’m starting to use some extensions such as the multi-drop-down custom field and the custom field searching extension. But I’m wondering if I use these features, since they are not part of EE, will I end up having trouble getting them to work with future upgraded versions of EE. It seems to me that if I use the query module vs the custom field extension there wouldn’t be future issues since the query module is always packaged with the full EE. Thoughts?
django6's avatar
django6
18 years ago
That’s what I was thinking. I’m worried if I create a bunch of web pages that rely too much on extensions or modules that are not supported by EE, it could be a nightmare trying to upgrade in the future. Even worse, if I rely on too much non-EE code, and the extension ends up dying and stops being supported that could also be a nightmare since now I have a bunch of web pages that don’t work and have a large part of the code that needs to be rewritten.
PXLated's avatar
PXLated
18 years ago
PXLated's avatar PXLated
Had that happen early in the game. I now try to avoid add-ons unless absolutely necessary. That said, there are some dedicated add-on developers that have been around a long time and consistently support their programming so it somewhat depends on reputation.
