FreeForm, Forms or Any form module, please help!
Ludvik Herrera's avatar
Ludvik Herrera
about 18 years ago
Ludvik Herrera's avatar Ludvik Herrera
Hello:
I just installed the FreeForm module (2.5.7) and it seems like everything is running. It installed to the DB. I Installed the module and set the fields.
When I submit the form, nothing happens, not even the redirect page nor email is sent.
I would appreciate your prompt help. I am not sure if there are any other modules or PHP preferences I have to set. Do I need to make sure I am running PHP Mail, SMTP?
When I send messages through my Email module in the control panel of EE, the massages are sent, so I am assuming that everything should be o.k.
Here is the form:
{exp:freeform:form form_name="curriculums" form_id="curriculums" notify="[email protected]" template="curriculums" required="name|email" send_user_email="yes" user_email_template="curriculums" return="es/gracias"}
Perfil
<input type="radio" name="perfil" value="abogado con experiencia" /> Abogado con Experiencia
<input type="radio" name="perfil" value="graduado de derecho" /> Graduado de Derecho
<input type="radio" name="perfil" value="practicante" /> Practicante
Nombre
<input type="text" name="name" value="" />
Email
<input type="text" name="email" value="" />
<input type="submit" name="submit" value="submit" />
{/exp:freeform:form}
Lisa Wess's avatar
about 18 years ago
Lisa Wess's avatar Lisa Wess
You might also consider posting to solspace.com; the creator of FreeForm.
Ludvik Herrera
about 18 years ago
Hi Lisa:
Yes, I’ve posted this question in Solspace. I also found similar questions, but they were all unanswered. I hope somebody here may help me faster than at Solspace.com.
Do you know of any other Form module or alike that would be easy to setup and probably have an attachment to it?
Thank you.
Lisa Wess's avatar
about 18 years ago
This module is the only one I’m aware of, and is extremely flexible and many, many people have success with it. You might consider copying/pasting a docs example and seeing if that works, then customize from there. That is how I would begin, at least. =)
Adrienne L. Travis's avatar
Adrienne L. Travis
about 18 years ago
Adrienne L. Travis's avatar Adrienne L. Travis
Ludvik,
I’m just an EE user myself, but if you’d like I can take a look at it – I use Freeform on several sites, myself. Can’t promise anything, but if you’d like to PM me a login I can take a peek!
Adrienne Travis
