Problem with LG TinyMCE extension
Peter Felix's avatar
Peter Felix
17 years ago
Peter Felix's avatar Peter Felix
Hello everybody. I have strange problem with LG TinyMCE extension 1.1.8. I’m using EE 1.6.1 and everything seems to be wright, TinyMCE is working, compression is working, I can choose WYSIWYG custom field or textarea in field settings, BUT there’s no difference! When I set field type as WYSIWYG, and another field as TEXTAREA, TinyMCE apperas in both filds. I need one field as tinymce textarea an another as blank simple textarea. I really don’t know what’s wrong. I’ve also seen the LG TinyMCE extension tutorial video. Could be the problem in EE’s version, cause on tne video, the’ve used EE 1.6.0. Thanks for help.
jlahijani's avatar
jlahijani
17 years ago
jlahijani's avatar jlahijani
I accidentally replied to this thread when I meant to reply to this one, however my post my assist you:
http://ellislab.com/forums/viewthread/61537/P18/#337987
Peter Felix
17 years ago
Thank’s but this isn’t my case. I’ve checked all field types setting as you wroteand they’re all SHOW BY DEFAULT. I have this problem also in IE7 or IE6. It has to something else. But what?
Peter Felix
17 years ago
Hello. And what should I write there instead of mode:’textareas’ ??? Thank you.
Peter Felix
17 years ago
I’ve found it - SPECIFIC_TEXTAREAS, EXACT or NONE. I’ve tried all, bud tinymce won’t appear?
Peter Felix
17 years ago
Problem fixed 😊))) Thanks
spacewalk's avatar
spacewalk
17 years ago
spacewalk's avatar spacewalk
What exactly was your fix? I’m using the LG extension and TinyMCE 3.0 RC1 and I cannot get the editor to appear when I set a custom field to the “WYSIWYG” field type in EE.
uvalibrary's avatar
uvalibrary
17 years ago
uvalibrary's avatar uvalibrary
To configure the LG TinyMCE extension to ONLY apply a WYSIWYG to the custom fields of type “WYSIWYG” (and not TEXTAREA), apply a configuration parameter as follows:
Step 1: in Admin > Utilities > Extensions Manager > LG TinyMCE Custom Field
TinyMCE Config: mode : "textareas", theme : "advanced", editor_selector : "lg_mceEditor", ... other stuff ...
Step 2: Explore the TinyMCE documentation.
Step 3: Profit.
