Wired,
Care to be a little more specific about what you mean by tab?
Do you mean the main set of tabs along the top?
Publish|Edit|Modules|Etc…
Or are you talking about something else?
The main set of Tabs only has one officially supported way of adding a tab. And that is to go to a CP page and click “New Tab” on the top right of the page.
Jamie
So you want to add a tab to the Publish form while adding or editing an entry. Editing a weblog is very different from editing an entry. Thus why I was so confused.
To do that you would need to write an Extension.
It is going to require some PHP/MySQL ability obviously.
The extension hooks you will need to affect are:
publish_form_new_tabs publish_form_new_tabs_block
You will also want to use a hook to deal with whatever controls you have in the new tab. The hook you choose for that will depend on your specific needs.
Jamie
