Plugin + Settings = module?
Erin Dalzell's avatar
Erin Dalzell
17 years ago
Erin Dalzell's avatar Erin Dalzell
If I am developing a plugin that requires settings, does that mean I need to develop a module instead?
Daniel Walton's avatar
Daniel Walton
17 years ago
Daniel Walton's avatar Daniel Walton
Not really, it depends on what the code is aimed at doing.
btw. You can pass settings to plugins via parameters, that could override default settings that are hard-coded into the plugin.
Plugins are there for typically small, perhaps textual, changes to content within templates. I don’t think they were designed to go much further (even though you do see plugins such as the official 1st party cron plugin) but can do so, because of their ease of implementation.
Modules would typically deal with, say, user input via forms, more complex template based output tags and a customised area within the control panel that can be used to administer whatever the purpose of the module is for (think mailinglist module).
Erin Dalzell
17 years ago
Ya, I understand the differences between them and it is a plugin I really want, but I need to have some settings.
I guess I will just have people edit the plugin file directly.
