NoFollow Plugin and Whitelist
mayest's avatar
mayest
17 years ago
mayest's avatar mayest
I started using the No Follow plugin a couple weeks ago for blog comments. It works great, except that it seems to ignore my whitelist. I think I’m using it correctly. Here is slightly stripped version of what I’m doing:
{exp:no_follow whitelist="y"}
{comment}
{/exp:no_follow}
I added a URL that had been posted in a comment to the whitelist, but it still shows up nofollowed in the source.
This plugin was created in January 2005, so I’m wondering if there have been some database changes that have disabled the whitelist support in this plugin? I’m using EE 1.63.
secondlamppost's avatar
secondlamppost
16 years ago
secondlamppost's avatar secondlamppost
I am having a similar issue with the No Follow plugin not excluding designated groups. I have tried to exclude 2 groups URL’s using the parameter “group”. Here is my code:
{exp:comment:entries sort="asc" weblog="blog|prof_ergo"}
<div class="{switch="comment_list|comment_list_alt"}">
    {exp:no_follow group="1|6"}
        {comment}
    {/exp:no_follow}
    By {name} on {comment_date format="%M %d, %Y"}
</div><!-- closing .comment_list div -->
{/exp:comment:entries}
I have tried excluding groups using the group ID and using the group name without any results. Every link in my comments regardless of who posted them receives rel=”no_follow” attributes.
I have also tried conditionals like this:
    {if member_group == "1|6"}
        {comment}
    {if:elseif group != "1|6"}
    {exp:no_follow whitelist="n"}
        {comment}
    {/exp:no_follow}
But I received the same results. Am I misusing this plugin? I found little in the forums regarding using it. Or alternately, is there a better plugin that would accomplish the same thing?
applepie23's avatar
applepie23
16 years ago
applepie23's avatar applepie23
I needed this to work so on line 111 I changed this:
if ($whitelist == 'y' && $DB->table_exists('whitelisted'))
to
if ($whitelist == 'y' && $DB->table_exists('exp_whitelisted'))
Yay.
mayest's avatar
mayest
16 years ago
Well, that seems to make sense. The next line of code is clearly constructing a query to pull data from the exp_whitelisted table. I’ll give this a shot. Thanks.
Yup, that seems to do the trick.
secondlamppost
16 years ago
Thanks Applepie23. I abandoned this after not getting a response and not being able to find the answer. I’ll give it a try and let you know how it turns out.
