Indicator of the sticked / future / expired entries
Gabriel's avatar
Gabriel
17 years ago
Gabriel's avatar Gabriel
I’m thinking about an Control Panel extension which will be change entry row color in the Edit Tab, when the entry is sticked and/or expired and/or future. I’m looking for a clever solution, how to indicate status of these properties directly on Edit Tab. I don’t want add next column to Edit Tab (there is lot of information now), so color indication will be better. What are you thinking? Is there any hook for that which push me right way?
ExpressionEngineer's avatar
ExpressionEngineer
17 years ago
ExpressionEngineer's avatar ExpressionEngineer
You might want to have a look at this hook; edit_entries_modify_tablerow.
Gabriel's avatar
Gabriel
17 years ago
ExpressionEngineer: Thank you!
ExpressionEngineer
17 years ago
Please let us know how it goes, I’m sure you’re not the only one in here who has though about this.
arnoldc's avatar
arnoldc
17 years ago
arnoldc's avatar arnoldc
I am looking to customize the entry row and found this hook edit_entries_modify_tablerow as well. However, how useful is this hook in this current form? The only pass-in parameter is the HTML content data, not the entry’s record. How am I suppose to rewrite the entry row without any info to play with? It would be painful if I have to extract data from the pre-formatted HTML row….
gridonic's avatar
gridonic
17 years ago
gridonic's avatar gridonic
How am I suppose to rewrite the entry row without any info to play with?  It would be painful if I have to extract data from the pre-formatted HTML row....
I’m afraid you have to play with it as it is, which means using preg_replace to put your stuff in or make any changes.
