Template Caching Variables?
Andrew Smith's avatar
Andrew Smith
17 years ago
Andrew Smith's avatar Andrew Smith
Here’s a summarised version of our issue.
We have a plugin that pulls various fields out of a query.
They are then pushed to the template via this method - for example, for author name.
$tagdata = $TMPL->swap_var_single($key, $row[‘author’], $tagdata);
Then our template code for example is:
{exp:entrylinks orderby="latest" weblog="{my_weblog}” parse=”inward”} {author} {/exp:entrylinks}
Unfortunately, when this returns multiple rows, and multiple authors, the Author name will not change.
e.g. if our result set is Jim, Harry, Jim, Ben
EE will output
Jim, Jim, Jim, Jim
Is there a method of variable flushing or something like that, which has been overlooked?
Moved to Plugins: Technical Assistance by Moderator
Andrew Smith
17 years ago
Found the issue, it appears EE doesn’t like the use of custom plugins messing with the {author} template variable.
Changing the variable to {entry_author} has fixed it.
Sue Crocker's avatar
17 years ago
Hi, Andrew. This question is more of a programming question than a technical support question, so I moved it.
