Plugin bakeoff - localized_text vs. LG Multi Language
matt romaine's avatar
matt romaine
17 years ago
matt romaine's avatar matt romaine
I’m about to develop a multi-lingual website that will need to display custom localized strings. So far, the best two options I’ve found are LG Multi Language and localized_text.
One is free, the other costs mad moniez. I would appreciate anyone sharing their experiences with either (or a better alternative). In fact, Leevie - sell me on your plugin so I support you!
cheers
Eric Barstad's avatar
Eric Barstad
17 years ago
Eric Barstad's avatar Eric Barstad
This is a month late, but I’m using LG Multi Language on a bilingual site and it’s an incredible extension. It’s extremely simple to use – you basically just use a conditional to determine what language you want displayed based on the url.
