Error inserting entries, specific module development
evasion's avatar
evasion
17 years ago
evasion's avatar evasion
Hello,
I’m currently working on some external EE module built with CodeIgniter. One of the thing I need to do is to import some complex XML into a custom weblog with relationships.
I do this in 3 step : - First insert data into exp_weblog_titles - Then insert data into exp_relationships - Then insert data into exp_weblog_data
Here’s my code :
// Insert data into exp_weblog_titles
$title_data[$key] = array(
    'entry_id'                    =>    '',
    'weblog_id'                 =>     $weblog_id,
    'author_id'                    =>    $author_id,
    'site_id'                    =>  $site_id,
    'ip_address'                   =>  $ip_adress,
    'title'                        =>    $title,
    'url_title'                    =>    $url_title,
    'entry_date'                    =>    $date,
    'dst_enabled'                =>    'n',
    'edit_date'                    =>    date("YmdHis"),
    'versioning_enabled'        =>    'n',
    'year'                      =>     date('Y'),
    'month'                     =>     date('m'),
    'day'                       =>    date('d'),
    'expiration_date'             =>     $expire,
    'comment_expiration_date'    =>     0,
    'sticky'                    =>     'n',
    'status'                    =>     $status,
    'allow_comments'            =>     'n',
    'allow_trackbacks'          =>     'n',
    'forum_topic_id'            =>     0
$this->db->insert('_weblog_titles', $title_data[$key]);
$title_entry_id = $this->db->insert_id();
// Insert data into exp_relationships
$relation_data[$key] = array(
    'rel_id'        =>    '',
    'rel_parent_id'    =>    $title_entry_id,
    'rel_child_id'    =>    $child,
    'rel_type'        =>    'blog'
$this->db->insert('_relationships', $relation_data[$key]);
$relation_entry_id = $this->db->insert_id();
// Insert custom data
$custom_data[$key] = array (
    'entry_id'    => $title_entry_id,
// Set child field
$custom_data[$key]['field_id_32'] = $child;
$this->db->insert('_weblog_data', $custom_data[$key]);
Everything work well, data stored in the database seems good (I’ve looked at some var dump). But For a few entry, the relation doesn’t appear correct in the edit panel : relation selected option isn’t the good one !
When editing I change it from the edit panel to the good one, it still don’t work. But when I change to another one, then save, then edit and change it again but to the good one, it works !
I know my question is a bit difficult to understand, but all help would be appreciated because I’m really stuck right now !
Thanks in advance !
Regards,
evasion's avatar
evasion
17 years ago
I’ve found the solution, post it there, it may help :
Here’s some nice wiki article about inserting relationship manually : http://expressionengine.com/wiki/Relationships_-_Under_the_Hood/
My error was to insert child id into exp_weblog_data custom field, instead of auto-generated rel_id :
// Error was : $custom_data[$key]['field_id_32'] = $child;
// Must insert auto-generated rel_id
$custom_data[$key]['field_id_32'] = $relation_entry_id;
Sorry for disturbing 😊
Leevi Graham's avatar
Leevi Graham
17 years ago
Thanks for this Evasion… I’m working on a new module that uses relationships as well. This could save me a couple of hours. Good work!
