version control?
Brad K Morse's avatar
Brad K Morse
17 years ago
Brad K Morse's avatar Brad K Morse
is there any way to implement version control in EE?
Ryan Irelan's avatar
Ryan Irelan
17 years ago
Ryan Irelan's avatar Ryan Irelan
Like use EE with SVN?
Brad K Morse
17 years ago
yes
Ryan Irelan
17 years ago
Add the entire EE site to SVN, including the templates (save them as files). I work with every EE site in this way. Since EE stores so much in the database, you’ll want to also do a regular db dump and store that file in SVN, too.
Does that get you started?
AJP's avatar
AJP
17 years ago
AJP's avatar AJP
You can also add versioning of templates (but they’re in the DB) and versioning of entries.
However, one big issue with EE in SVN, as Ryan says, you must be backing up copies of the database as well, or SVN is CMS/uploaded files only, with no DB.
