LG_Polls - How to show all finished pools (results)?
macpro's avatar
macpro
17 years ago
macpro's avatar macpro
Moderator’s note: Moved to Modules.
Hi fellows,
i just stumbled across a problem with LG_Polls: How can I display all finished polls (results) on a single page. like an overview? That means more than one poll/result. I can’t find any similar example in the LG-Polls docs.
Thanx for any answer
macpro's avatar
macpro
17 years ago
No Idea? I can’t even reach the author Leevi Graham…
Greets
Leevi Graham's avatar
Leevi Graham
17 years ago
Hey MacPro,
You can just loop over the polls weblog and display the {results_answers} template tag pair and not the form.
Hope that helps
Leevi Graham
17 years ago
No Idea? I can’t even reach the author Leevi Graham… Greets
Maybe a PM or using the contact form on my website 😉
macpro's avatar
macpro
17 years ago
Hi Leevi,
i will give it a try. thank you. i just send you an e-mail days ago w/o response 😉
macpro
Leevi Graham
17 years ago
My bad… must have been eaten by my overzealous spam filter 😊
macpro's avatar
macpro
17 years ago
Thanx Leevi.
I got something wrong in my setup. I can’t get {if show_results} get to work. nothing is going to display. All temp checks I included are working and showing up, exlude all stuff inside {if sow_results} {/if}.
My sample/test code
Greets, Stefan
