how to MSM-ify a module
elwed's avatar
elwed
17 years ago
elwed's avatar elwed
Can somebody please post a short summary of how to make a module MSM-aware?
Derek Jones's avatar
Derek Jones
17 years ago
The short answer is that your database tables will want to have a site_id key to keep data separate and make querying for the correct data simple based on the currently site ($PREFS->ini(‘site_id’), or the $TMPL->site_ids array which will automatically be set for you when a site= parameter is used in your module’s tags. You could also of course use a table to control member group access to your module in specific sites if you wish, again, with site_id being the key.
elwed's avatar
elwed
17 years ago
Thanks, Derek. I’ll compare notes with other modules to see how far I’ll get 😊
Derek Jones
17 years ago
No problem, let us know if you have specific questions about the implementation, Markus.
