TinyMCE not loading when using bookmarklet
barchas's avatar
barchas
17 years ago
barchas's avatar barchas
I know its a plugin, and not supported but i didnt know which forum to post it in, so move if appropriate and I will submit to 10 lashings.
I am having an issue where when I try to post about a webpage I find, by using the bookmarklet, my CP tabs at the top do not load and TinyMCE doesn’t load?
I am running MSM, and it happens on all 3 sites. If i go to the publish tab via the normal “i want to post something” route, everything is fine of course.
Anyone have any idea as to what might be causing this?
added: I am using LG’s extension as well.
Moved to Plugins: Discussion and Questions
Sue Crocker's avatar
17 years ago
Just a quick note, barchas - I moved you over to the Plugins forum. There are a number of community members that use TinyMCE and should be able to help.
I personally have never used it. 😊
barchas's avatar
barchas
17 years ago
no worries, i obviously missed this board in the list when I posted. Lashings are commencing…
barchas's avatar
barchas
17 years ago
Ok i fixed it in case anyone else has the problem. I just removed the &Z=1&BK=1 from the bookmarklet URL code. Not sure what they are for, but things work the way they should it seems, so good riddance 😉
now to post about a new problem… lol
