LG TinyMCE extension not working
Narzula's avatar
Narzula
17 years ago
Narzula's avatar Narzula
Greetings,
I have installed LG TinyMCE (v.1.3.2) into EE (v.1.6.4) with TinyMCE (v.3.2), following these instructions. When I then try and add or edit a custom field there is no option for “LG TinyMCE” as a field type. Previous to this, I attempted to install an older version that applied the settings to text areas, and that didn’t work either.
Thanks for any assistance!
Narzula's avatar
Narzula
17 years ago
Update: reverted back to previous version as new version just won’t work. [removed].
Leevi Graham's avatar
Leevi Graham
17 years ago
Version 3+ renames the custom filed type to WYSIWYG 😊
