Solspace FreeForm 2.7
Jason McCallister's avatar
Jason McCallister
16 years ago
Jason McCallister's avatar Jason McCallister
I am not having an issue with the FreeForm itself… Just the control panel for FreeForm. I want to show a summary of a “few” fields so it doesn’t run off the edge of the screen.
I attached a screenshot.
Anyone know how to fix this?
Gabriel's avatar
Gabriel
16 years ago
Gabriel's avatar Gabriel
It seems not problem with Freeform. You just only put long word without space.
Jason McCallister
16 years ago
I’m pretty sure it’s Freeform. When I create a form with, lets say, 20 fields and I submit it it shows all 20 fields in the FreeForm CP.
I’m looking for a way to only show 3 fields in the CP, not all 20. Does that make more sense?
Gabriel's avatar
Gabriel
16 years ago
aaah, you’re right. You should post on solspace forum http://www.solspace.com/forums/viewforum/10/
